Can someone answer a bit of a general query regarding supports.
Id quite like to learn support properly and looking at sona and janna in particular but dont get a fundemental part of it. If you look on the likes of lolpro supports pretty much get the same stuff, youve got your sightstone then the likes of shurelyas reverie, mikaels crucible and locket of the iron solari. The latter three just really give you real good regen but surely youre missing the AP that you would get with the midlaners so although youve got a lot of mana and it regens quickly, all your spells do next to nothing due to having such low AP.
Last game i had janna and had her shield but it was so miniscule it almost seemed to be not worth the bother.
Also would a tear not be a good buy for support to make sure she has plenty mana? Never sen it on any the builds ive seen.
Another quick question, i came across an item the other day though cant remember the name but basically after 3 levels the item disappeared and the effects were now permanent. Id have thought with something like that which would give a permanent effect and then free the slot back up, loads would get it but never seen one person. Is there a reason that im missing?
Thanks
