Zowie mouse guide
7 Feb 2011
Stoke on Toast
A writer on ESEA has done a comprehensive explanation of zowie mice which many of you may find interesting if you are looking for a new mouse.
All of which can be purchased from ourselves so I figured I would link the information for you all
http://play.esea.net/index.php?s=esports&d=comments&id=12902
About the Mice
ZOWIE eVo Series:
The EC eVo series offers two different sizes of ergonomic right-handed mice with unparalleled performance, stability and functionality. The EC eVo's are plug and play mice with 1,000 Hz from standard, which can be easily changed to 500 or 125 Hz directly on the mouse. The EC eVo has an incredibly low lift-off distance of only 1,5 mm, due to the custom-developed ZOWIE lens.
ZOWIE FK:
The FK is similar to the AM in terms of specifications and features, and they are both ambidextrous mice developed for gamers who prefer a claw-grip play style, but that is where the similarities end.
The FK is an ambidextrous mouse with a \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\/ grip, contrary to the AM that has a /\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ gripping style. The design of the FK has changed slightly compared to the AM, amongst other minor adjustments, the height is lower. The adjustments to the overall design have been made to make the FK lighter and faster. We hope that the design makes it more comfortable to use, not only for gamers who prefer the claw-grip, but also for gamers with smaller hands who prefer to palm-grip their mouse.
Furthermore the FK features a new coating, which feels smooth and fine like regular rubber paint, but has increased resistance towards wear and tear. The coating helps increase grip for gamers with tendency to sweaty palms and it is easy to clean!
ZOWIE AM:
The AM is a series of ambidextrous mice that is unmatched by other mice in flexibility, stability and performance. The AM features two buttons on both sides which allows the user to switch between left- and right-handed usage. Only one side may be active at a time, thus eliminating annoying situations where you accidently hit the opposing side-buttons, resulting in an awkward situation, costing you a kill – or the game.
AM: Full rubber coating
AM FG: Full white gloss
ZOWIE MiCO:
The MiCO is a small, lightweight ambidextrous mouse, designed for gamers who prefer the claw-grip playing style. It was developed with feedback and inspiration from some of the leading StarCraft 2 players in the world. It is the preferred mouse of legendary gaming teams KTRolster and StarTale.
The MiCO was developed for gamers who looks for quality, stability and performance. You will not settle for second best, and you do not want to mess around with complicated software before you can play.
Because you just want to plug and play - like a pro.
To view the whole range of zowie mice that we sell.
http://www.overclockers.co.uk/produ...&catid=23&sortby=nameAsc&subid=1257&mfrid=582
OH MY :eek:
I was just about to post a thread regarding EC1 eVo vs FK :o
Im moving from a G500 so any advice welcome :)
Also could you explain this to me.
I dont understand the grips?
im assuming the \ / is where the thumb lies, so on the first one, its ambidextrous, so the thumb lies on its right hand side just as well as the left, where as on the other it wont?
no idea if thats correct, but it makes sense in my head lol
OH MY :eek:
I am looking into this for you. try and find out what the author meant.
Looks to me like palm Vs claw grip but can't find anything to confirm.
OH MY :eek:
I would have said it's palm vs claw?
Then again, could also be the shape of the mouse with, \ / wider at the front and / \ wider at the back.
I have the AM, very happy with it and the first mouse that isn't made by MS that I have felt totally pleased with.
Regarding the shape of the FK, the \/ shape actually refers to the sides of the mouse.
The FK tapers inwards from the top to the bottom for a \_/ cross-section, making lifting it with your thumb and ring-finger much easier.
Mice with the opposite cross-section require a tighter grip to lift it off the mousing surface, potentially causing a little more instability.
The difference is subtle, but pronounced when being used IMO.
Thanks I've still been waiting fro a response from the author lol
