Its quite easy, you just have to make sure you take your time and apply gentle even pressure. Also i recommend getting one of those stanley blades that you can snap off as you go as they seem to be the thinnest at 0.41mm so it doesnt bow the cpu as much when peeling the corners. Also you must try not scrach the cpu surface or go too deep that you hit the die. But as i say i was an amature at it and it wasnt hard at all really.
Dam worth it!![]()
Id thought about it with my current cpu, but as it's such a poor clocker, (4.5ghz at 1.330v) it's not worth it. Id only delid a good low voltage clocker that i wanted to push higher. Not something this current chip is capable of, as the voltage increases required would be way too high.
For anyone that does delid, coollaboratory liquid pro/ultra is the paste of choice. Also, if cutting with a knife/razor. It's reccomended to cut one corner with the blade. Then use firm plastic, (takeaway container lids are ideal) to work the rest of the way round. Less chance of damaging anything.
The screen has a mac mini strapped to the back of it. Nothing to do with the OP's new build. Shhh.Good work there.
Surprised you've got away with posting the OSX install screenie though, I posted a screenie in the OSX desktops thread from my Hackintosh and it got removed rather quickly by one of the mods.
!Good work there.
a pictude speaks 100 wordsThe screen has a mac mini strapped to the back of it. Nothing to do with the OP's new build. Shhh.![]()
Lovely build mate well done. Risky delidding the cpu though!
yeah i like a bit of a thrill, i was a bit wary but i simply couldnt resist!looks like photobucket wants your money, god I hate it so much.
Nicely done. Although the window is very tidy, I don't like it as it's the opposite of the intended aesthetic of a Mac case. Still, just personal opinion. Epic job though, probably the best Mac Pro case mod I've seen!
Also, check out imgur for image hosting. Much better than photosuckit
Your cable management is awesome. Very nice indeed!
