- 25 Mar 2004
- Fareham
Purchased a new build property recently but I'm wondering about the Seal for the shower. Can you guys check out the pictures below and let me know what you think?
The first picture shows the right side of the frame looking out from within the shower, so they have put some mastic on the bottom of the frame but none on the inside edge going up, is that right?
This picture shows the bottom of the frame, this sits on the lip of the shower tray, and there is no mastic on the bottom edge so the water seems to get through and sit on the other side of the frame.
This one shows the left edge, again no seal on it.
This one shows the bottom edge of the tray/frame looking in from outside. The water gets through under the frame and pools between the frame and the edge of the tray.
I reckon I need to get the builders to seal the bottom of the frame on the inside of the shower, what do you guys think? Presumably the inside of the shower frame going up doesn't usually have any sealant applied, it's sealed on the outside edges.
