Fully Enabled GK110 Arrives
2 Nov 2012
So the full fat GK110 will be release by Nvidia in the form of the Quadro K6000.
The TDP is 225w so clocks are going to be lower than Titan.
Bandwidth is 288gb so 6ghz memory clock.
This thing packs 12gb ram!
Full fat 2880 cores.
Would this make it as the Titan Ultra?
Source
I had to recheck the GK110 architecture since I thought Titan was already fully unlocked... guess I was wrong. Sheesh, this thing is going to be one heck of a power house then. When do you think we'll see the mainstream version? When will Nvidia stop milking Kepler and move onto the next achitecture :p?
Some time after the opposition get off their butts and bring something new to the table.
I wouldn't be at all surprised to see Nvidia not release their titan II/ultra or whatever they will call it until after the new range from the opposition that way they can clock it just enough to beat the opposition.
Getting pretty tired of it all now, roll on next year and the new process with new ranges from both parties.
Agreed, from this point on it's time for some new products, no more extra enabled cores or high clocked parts. New architecture plz ! Especially from AMD, they are taking their sweet time..
Surely they don't need to release anything so soon, i mean....all your cards play everything @1440p MAXED OUT? Don't they? Super smooth framerates, constant 60fps and all that jazz?
Like i said months ago within 1 year that a Fully fledged GK110 would appear and that the crippled cluster that Titan has would be enabled in the Ultra/Quadro...and here we are.;)
Not this card, but the technology will. :)
Not particularly, it's not a huge step up from the Titan as it is, to a full GK110, especially considering the likely lower clockspeed due to the increase in shader clusters.
This is why GTX780s can overclock to higher clock speeds than the Titan whilst using the same amount of power, as it has less clusters than the Titan, it will hit the TDP limit slower whilst increasing clock speeds.
Some games respond more to an increase in clockspeed over an increase in shader clusters.
I can agree with you about the Quadro, because it's here, but, I can't see them release a Titan ultra, or II or whatever you want to call it. Wouldn't the performance in games be nearly the same as Titan?
