Caporegime
- 9 Mar 2006
- Surrey
I think it depends how you use metallics as well, I mix them in with layer paint so perhaps that helps with my consistency (brown and gold for example)
Yeah I've tried to read that codex and make a list and I just got confused as hell![]()
aceytrixx, a tip for magnetising stuff, use a spare base and glue a magnet on that, with the orientation for the weapons to stick to the "up" side of the magnet.
That way you can stack magnets on it and be sure that they are the right way up when you go to use them(vehicle side magnets from the bottom of the stack, weapon side ones from the top).
It greatly reduces the risk of you putting a magnet into the hole then finding it's the wrong way round to mate with the other magnet.
