- 5 Sep 2011
- Surrey
Think these are for OpenGL 4.4, not much else
326.29 drivers here, working great, no issues whatsoever so far.
im currently on 314.22, is this the best driver at the moment ? i have a gtx 560
Any one play BF3 & noticed with the 326.01 & 326.29 drivers your CPU core's all running at 95%-100% in BF3 ??? A friend & myself have this as we have the same set up (CPU-i5 3570k & GPU-GTX 780)...
Before this my cores never got over 80% & my FPS would be 100+ but since I've being using these drivers my FPS drop to around 44fps due to the CPU running at 100% & making a bottleneck ! This courses stutter & large FPS lag... It doesn't matter what setting you have (ie High, Med & even low) it still maxes out the CPU cores ? The GPU is at load of 98% & temps around 70c...
If you have v-sync on you may not notice but if you can look at your CPU load whilst playing to see if its happening to you ?
Now, surely a i5 clocked @4.6 with a max temp of 60c is not enough power for a GTX 780 ? My old HD7970 was smooth & settings were lower but I still could get large FPS & never seen them drop to below 60FPS + the CPU would sit at 70%-80% !
Any thoughts or feed back to see if it happens yourselves, this may not be limited to us GTX 780 owner & could be a GTX TITAN issue too ? Also anyone still on 320.49, does this happen to you (I can't use this driver due to the BF3 corruption but will test it later tonight) ?
I'll take some screen shots later tonight...
Big problems with these for people with 120hz IPS monitors like the Catleap etc.
My Overlord gives a blank screen and so do the quadro equivalent.
I got driver 320.8 with 770 lightning and so far that has been the best working driver for me... been trying out the last few driver updates...running driver 326.29 the last couple of days, not notice any issues as yet!
I have a pair of 770 lightnings in SLI and I'm worried to update drivers 326.19. I'll wait for proper non beta drivers.
