- 6 Feb 2010
I highlighted that bit just to make it stand out more. I'm actually quite surprised that being a graphic card forum such as ours, there are SO many people don't even realise having a narrower memory bus mean frame rate would dip at a faster rate (in terms of percentage) than wider memory bus.Because it has a lesser GPU?
However, if you observed the falloff in performance from increasing AA, the 3GB 580 would lose less FPS (as a percentage) from increasing AA/res than a 670 would.
Additionally, a 3GB 580 isn't the standard model, the standard model is 1.5GB on a 384 bit bus.
It is also the same reason why the GK104 cards would have frame rate drop to below AMD card of the same tier level on the higher res. Far too many people going round in circle talking about the amount of vram, whne it is the bus size that's holding back the cards the most.
