Most people guide you to increase the voltage and core clock etc. but what does the power limit do?
Im currently OCing my 7950 at 1.15V @ 1050mhz and just realise I am able to adjust the power limit (MSI Afterburner). Some guides suggest that increasing the power limit should be used for "rookies" (if you know what i mean). So does that mean i can tweak my card by altering the voltage AND power limit?
the card was throttling itself as it was unable to draw enough power to preform at maximum clocks. Gl and hope to find out your results - btw youve got your card stable at 1150, what sort of clock can you get on your memory?
mrs naggin in back ground while reading
, atleast your advice is sound - dont overdo the voltage lol
