DengFu: £250
You'll need more than a frame though?
(and i doubt you can get one for £250)
DengFu: £250
I dunno, what do you guys do?
Mmmmm, uhhhhh, well it sounds about right; however, you're only doing rides like that occasionally aren't you? So you're not really going to go into 'deficit' unless you're doing it every day. You'll just get more hungry tomorrow or the day after and catch up.If it is correct, I need to eat another 2500 calories to stay out of deficit according to my fitness pal. Do I need to do this? My goal is to stay roughly the same weight, maybe lose a kg or two, but hopefully continue gaining muscle.
I find this all a bit confusing, eating another 2500 calories would be a bit of a task today as I don't feel that hungry.
That's a BIG breakfast! What do you eat to get that many calories in, out of interest?Usually just have a large breakfast of 800+ calories, then fuel as necessary after the first hour and a half or so. Depending on the state of glycogen stores before breakfast is the key to when/if you are going to bonk in my experience.
Why so persistent, today?
all my Jerseys are a Large. so I bought a Large Rapha Team Sky top
not checked their website for sizing though, all feels ok, just an odd cut
I built up my Спорт into a bike this afternoon and took it out for a quick spin before I take it to work tomorrow. So I've used my 32-spoke Velo Orange P-B-P rims for now which look just like the original sprint rims it came with. I've got my black Michelins on, which at 23c are VERY close - there's about 2.5mm clearance between the rear tyre and the seat tube, so any run-out on the wheel is NOTICEABLE! I'll probably switch to my Tanwall 20c's which look like the original tubulars. I've got the Campag twin pivot caliper doing braking duty and I used a pair of ultra narrow 1980's curly drop bars I had in the loft. I've also dropped the gearing down to 48-18 from 48-16 to give my knees a break for a few weeks. I can't take a pic until tomorrow because my camera is at work but this is it a few weeks ago before the build, so imagine it with bars and cranks and we're there:
So what's it like to ride? Well it's tall and very short. There is an absolutely outrageous amount of toe overlap with the front wheel because the end of the crank comes to within about 40mm of the tyre. The Bob Jackson had a lot, but I'm going to have to learn to get used to this because you can't steer very far at all if you're foot is there! It's a sprint frame with very steep head tube. When you accelerate, the bike stays dead upright and doesn't want to steer at all. Everything you put into it goes straight into the wheels and it accelerates VERY fast
So far so good, but I'm a tiny bit concerned about the threadless bottom bracket I've had to use. It didn't wind on many threads so I'm a tiny bit worried about cranking it up too tight. I'll give it a nip up tomorrow lunchtime after it's settled but I don't want to give it too much just yet.
I do about 20 miles a day and I can feel it if I'm not eating enough. I generally settle around 3300-3500 calories a day, a bit less in this weather, but my appetite varies depending how much I'm doing. You'll know when you go into a real deficit - firstly you'll start losing weight (fat first), then you'll just feel lethargic and your strength will start dropping.
Went and watched a MTB race today as the tracks just opened near me.
Rode over as I've not really used my MTB much, did a couple of laps before the race. Had my front wash out on the first lap and fell off. Punctured on the second... Maybe I'm not meant to ride MTB anymore!
This is disgusting to hear Berger!
It's ok. It's winter over there, MTBing is permitted![]()
So what I'm asking is, anyone with Rapha jerseys , how are they for you?
I've compared it to my TORM and its slimmer cut, slightly longer in the arms, and the neck is a bit smaller but the torso length is a lot shorter
It doesn't feel tight though, im wondering if I need a bigger size...
