just delidded my cpu.
first i used mx4 and got actually worse temps than stock. i wasnt happy
bought some coolaboratory ultra and its, wait for it, 40 degrees cooler than it was before.. max core temp of 62 in prime. where before it was approaching 100.
this is bare die mounted, im sure if you delid and still use the ihs then mx4 is fine, but damn, i remounted it 3 times with the mx4 and still sucked.
so to conclude, if you are bare die mounting, then use coolaboratory, insane!!!
my cpu is now cooler than my i7 920 was hehehe, happy days
Great Board!!! So your stable at 2133mhz??
4.4Ghz @ 1.26v. My god this thing flies, I'm getting throttling in Intel burn test and Prime 95 though. Anybody else throttle in these progs?
vcore is 1.36 for 4.8. it goes up a lot for me after 4.7, which is happy at about 1.275ish
and yes its great, not sure i want to push higher, just happy having it running at the moment![]()
not that 30 mins of prime confers stability
Not that Prime shows anything at all!!! more like!!! Prime who care, I dont play, bench, encode, Brows, listen to Prime!!! Who the hell does???
