- 2 Jan 2012
- UK.
I haven't had any throttling in prime, not run IBT. Not happy with temps overall though, particularly as I'm only 1.23 vcore, would like to increase clock to 5ghz but more voltage required for that so seriously thinking about delidding, need to decide on vice or razor method though!. If I do go ahead I'll re-mount naked using the EK precise mount kit with some coollaboratory liquid pro.
Yeah the temps on these chips are very high, my chip can hit 82c @ stock settings running Intel Burn Test
Overall though the performance VS low power use is awesome. Run my chip at stock 24/7, would be nice to be able to crank it up for the occasional benchy or encoding, but my chip does not like to be OC lol. This is ideal to tide me over until Haswell -E in a couple years though. Hopefully the heat issues will be resolved by then. No IGPU etc might help a lot..
