BF3 was already smooth anyway, tried some other games and I can't see any difference at all.
because it will "fix" if you have the problem.. if you don't have the problem, you don't have anything to be fixed![]()
Huge difference with crysis 3 on crossfire...before i used to get awful stutters where the fps would go extremely low i just played a few levels and didnt get any..Also i was able to increase the graphic settings and its still very smooth now. Im getting more fps + no stuttering.
Any difference at all means they still stutter![]()
Far Cry seems smoother. Shame I've lost my save game for it and I won't finish it![]()
really no stuttering and more fps?
seems like it was a miracle driver
It did seem slightly better by a little.
Did uplay not cloud your saves or did you have that disabled.
Disabled! I need someone to send me one that is saved local, tried downloading some that are online but they don't work.
If you get this i shall send you my save to use with that if it works.
Not sure how far i got with that save though as i do use uplay cloud now,
http://www.gamesave-manager.com/
