Yes thats at 4.8Wow, 62c I assume at your 4.8GHz oc? that's awesome, even cooler than my 4.8GHz on my old 2500k. Enjoy man
Whish I had the balls to do this myself but I don't think my old ticker would stand the strain![]()
mx4 is a waste of time on the die,been there done it
you HAVE to use coolaboratory on the die/top of internal heatsink
Delided my 4770K today... I used the blade method... I had a quick go at the vice method and nothing happened, so I chickened and went back the blade which I had done before on my 3770K. Unlike last time where I used a modelling knife, brought some single sided razor blade / safety scrapers which went through really easily as they are so thin. Took no more than 5 minutes to have the IHS off.
I can't bring myself to do the bare mount so I put Liquid Metal on the silicon and then the IHS back on.
A quick go on air gave good results 4.8GHz 1.26v was recording 72c on the hottest core after 10 minutes of Prime 95.
Time to decommission my 3770K and put the Haswell setup in my Corsair 540 case - twin rads and lots of fans.
James - did you try with the IHS back on?
Should I be braver and try without it do you think?
you can buy an ek naked mount then mount your cooler to it?
you won't risk crushing the die that way
