I've always been a die hard wmo user (and quake player) and the only fitting mice for me are a coolermaster storm spawn/xornet (****e sensor on the xornet though) an abyssus, or a kana.
Have to say the sensor on this is fantastic, lift off distance is perfect coming from the WMO, so far not seen it skip a beat or become erratic - very smooth without a hint of unwanted acceleration or prediction.
)How are you finding the side buttons? Did the world implode when you inevitably touched one?
(Yes I'm taking the ****)
Really liking the combination of FK + camade + N-RF2 - only real negative is the mouse wheel which is liveable with but requires a little too much force to use to be ideal. If they fixed that and made the mouse a tiny tiny bit fatter it would be a complete superior replacement for the WMO 1.1a in every regard.
(I am a very old school FPS player - arrow keys for movement, the block of 6 keys above for most functions, fire left mouse, jump right mouse).
We're a dying breed.![]()
If you don't find anything to suit, maybe you will just get used to the slight differences with the death adder. Sounds about it's the closest you've got so far.
