Will the old steering wheels work with the xbox one?
Doubt it.
At E3 the Forza demo had a prototype thrustmaster wheel. So I doubt Fanatec wheels will work on the new Xbox.
Have they shown a wireless headset? I've only seen the wired one.
Hmm annoying. Just been looking at the T&Cs for using Nectar points on their Enterntainment website. Looks like you have to spent your Nectar points on vouchers specifically for the Entertainment site (maximum of £50 voucher available) and you can only use ONE voucher per transaction :/
Was hoping I could use the £150 of Nectar points i'd collected on my Xbox pre-order.... apparently not :/
Thinking about it, I guess I could do 3 separate transactions.. one for just the console, one with a game and one with some accessories. hmmmmmmm
Just pre-order at the shop. You will get 1000 points (£5) for that.
Anyone with an amp wondering how it'd integrate? Can't see (more hope) it won't be a problem. I can't seem to find much info on it.
When we say 4K HDMI cable, we mean it. The HDMI cable we’re including is an actual Category 2 HDMI cable, rated for 1080P, 3D and 4K, according to the HDMI 1.4 spec.
The built-in wireless on Xbox 360 just supported single-band A/B/G/N @ 2.4ghz. The Xbox One wireless radio is A/B/G/N, but supports dual-band 2.4ghz and 5ghz frequencies.
The console shown in the video is one of the first production units – less than 20 exist in the world (and yes, this box has the 853mhz GPU).
When you plug a micro-USB cable into the controller for wired gameplay, the internal radio is actually shut off, transmitting data through the wire. You can even use the controller without batteries in this mode.
180 (DRM) + 180 (indie) + 180 (headset) + 180 (???) = Xbox 720.
Waiting for gamescom to unveil their final 180.
Why the power brick again?
This alone is enough to put me off
The one on my original 360 really irritates me and they got rid of it on the later 360's if i'm correct?
Why a step backwards with this?
