what is this 'mark'....
Caporegime
13 Jan 2010
Llaneirwg
you can see a pentagon on the phone
Shot was tested with a 50mm, 5 blade aperture lens
It isnt always the same size
it isnt on the lens
its on a friends camera
EDT, 50, not 500mm, typo
also tried macro lens etc and still present
Refraction from lens element?
To eliminate if its dust on sensor. Put a lens on, shoot at something white and wave it around for 10 seconds or so at F 18 or something.
you mean leave the shutter open for 10secs?
Could be a dust bunny on the sensor :)
thought it might be this
due to my newness to this, why does the mark change size with differing focus if it is in the body?
Yes, by waving it around you are moving everything else, if its dust then the dust on the sensor won't move, the stationary object is the dust.
Hence why I said wave it around.
