 - 8 Apr 2012
 - North wales
some one tell me best ones to drop to medium please and whats AA?
Your Cpu will hold you back running high or ultra mesh quality. So I would say mix of low/medium settings.
I'm surprised I had a 6850 and at low settings I was getting 30-40 fps
hi guys thanks for reply yes it is phenom II 6 core @ 3.3ghz turbo and can go to 3.4ghz stable
ive also over clocked gpu slightly increased the gpu clock from 850 - 900mhz and memory clock from 4800 - 4900mhz
kinda getting mixed message's now should i run low -medium or medium- high , i am using a 22" wharfedale hd tv as monitor through vga and dvi on graphics card
hope this helps
how's this- turn everything up and if it doesn't work start turning stuff down until it does![]()
lolwut? BF3 isn't even demanding dude. It's only demanding if you use Ultra settings... For high with no AA a 1GB 6850/6870 does the job.
 didnt think the old card had it in it lolCheck your GPU usage, so you would know if you need to overclock the graphic card or the CPU to bring the frame rate closed to 60fpsit show when i run fraps that im getting between 50-70 fps
it seem to be playing fine now on high settings quite impresseddidnt think the old card had it in it lol
