Hi i would appreciate some help on this if possible.
I wish to overclock my FX-8320 3.5Ghz (4Ghz Boost) to roughly 4.2 or 4.3 depending on temperatures. Hopefully this can be done by just using the multiplier as i don't really want to go near voltages? I need to know exactly what things need turned off and what exactly i should be changing to achieve the desired overclock.
My mother board is a Gigabyte 990FXA-UD3 AMD 990FX (Socket AM3+) DDR3 Motherboard. (The Newer Bios version which doesn't look like a normal blue screen bios)
I am currently using a Thermalright True Spirit 90 CPU Cooler with a Zalman Z9 case with an extra 2 120mm fans so plenty of through air.
Idle i sit at 7C-10C and full load around 45C.
Here are a couple of screen prints on full load.
If you need anything else please let me know.
Sorry if im being a newb but this is all new.
