****Folding@home setup guide****
23 Jan 2010
St helens
im on windows 7 ultimate and myn NEVER freezes
in internet options i ticked the box
use softerware rendering instead of gpu rendering, never had a freeze since, before hand it was VERY laggy
14 Aug 2006
just joined
Hi
I just joined up to the team.
AMD FX-8530 piledriver + Nvidia Quadro K4000
Currently generating 30/31k points per day.
Paul
23 Jan 2010
St helens
hi there , from the net it seems that the k4000 is about the same as a gtx 660 , one you have completed 10 work units on the cpu you will start getting bonus points so your points per day will rise more.
also did you get your self a passkey? :)
welcome to team 10 ! :D
18 Jun 2009
Rugby
Morning all,
I have joined the folding team.
I kind of understand what it is, and the need for it, dont really understand how it works, but more research is incoming!!
I have my machine on for a few hours each day but not used so will crank it up to full each day for couple of hours, see if i cant help get some points :)
i'm kind of hoping my rig will crank out some good points, if not, well at least i have clear justification to upgrade!!!
18 Jun 2009
Rugby
Quick question though, i registered with team 10 and asked on the folding page for a passkey, entered that and then it started, do i need to do anythign else to register with OCUK team?
18 Jun 2009
Rugby
Well, 2.5 hrs in and 1 CPU project is done with the GPU on 50%.
Really spanks up the temps in my case lol.
CPU gone from 30, 31, 33, 30 up to 55, 58, 56, 56.
GPU not even breaking 60 :D
So far running a PPD of 17987.
Lord only knows if that's good or not
23 Jan 2010
St helens
after you complete 10 work units on the cpu your points will go up a huge amount as you get huge bonus points.
you will get more than 17'000 ppd in a few days :D but even so, what ever you add is welcomed by every one :)
RHS
RHS
14 Feb 2013
Fife
Just joined the folder gig, I used to crunch SETI results back in the day, signed up to team 10 to help out.
Running a Quadro 2000 along with an Intel Xeon @ 3.2ghz.
Currently returning 16,000 units per day.
31 Mar 2012
Hi guys, just joined and am now folding on the CPU.
I tried folding on my GPU (GTX 780) but although I am assigned a project, it doesn't utilise my GPU at all and is stuck at 0% after several hours. I used the GPU auto-detect feature. Any thoughts?
23 Jan 2010
St helens
Hay man, check them emails ;)
download latest folding client, everything is in the email , including were to get a passkey.
you and your 3930k :o and 780 will be very very very welcomed to this team :D:D
23 Jan 2010
St helens
It's about time this was updated.
At this minute and time the best solution for folding I think is to download the latest folding client, it has quite a lot of options and caters for new and old gpus by allowing you to add the tags for the newer cards to fold the better units , and netting you much higer PPD.
folding program http://folding.stanford.edu/
passkey http://fah-web.stanford.edu/cgi-bin/getpasskey.py
the first thing to do when you've installed the program should be to click the folding icon in the corner and advanced control , the client will open and youll see a bar that says folding power , slide this across to full otherwise gpus wont work !
you will need your set your user name, team number and passkey which is done by clicking the folding icon > advanced control > configure. This takes you directly to the identity page
as you can see the team number is 10 , if you don't put 10 you wont be part of this team
now once you've done this you will need to set up the tags on your gpu client providing you have a 600 or 700 series gpu , the AMD range of cards im unsure as to what model you should add the tags to be anything like the 7850 / 7870 or 7950 / 7970 would be best.
ok onto setting up the tags.
if you click the folding client and then click advanced control it will bring up a nice looking client.
you need to click the CONFIGURE logo at the top , you will now be met with 7 pages as you will see , you need to click the slots, in thereyou will
see cpu and a gpu , double click the GPU , now another box will have opened, if you enlarge this box you will see at the bottom there is 2 buttons
add and remove, you need click the add button , yet again another box, dont worry this is the last box !!!. In this box you need to type 2 things as such
value: advanced
now these have been typed, click ok, now on all of the boxes click either save or ok will youve closed all the boxes down
couple of pics to show what I mean.
when you have clicked configure and selected the " slots " page it will look like this.
once you have double clicked the GPU icon and clicked the " add " button , you will see from the below picture exactly what I mean by typing in the values into the boxes.
9 Oct 2009
been folding for a few weekends now and just realised ocuk had a team, so im signing up.
what im using
main gaming rig (80k ppd)
i7 980 4.1ghz
2x gtx 680's at 1188mhz (soon to be 780's)
fah/web browser (19k ppd)
amd fx-4100 4.3ghz
gtx 465 875mhz (soon to be 2x 680's)
23 Jan 2010
St helens
what im using
i7 980 4.1ghz
amd fx-4100 4.3ghz
good on you mate :D you'l be much welcomed here! :cool:
have you added the tags I have showed above mate? I don't think you have as just one of the gtx 680 will get 80k ppd on its own :o
you will need to do it for each of the gpus , click on one gpu then add the
value : advanced
then you will need to click ok then do the same for the other gpu , in the above picture you will noticed it only shows 1 gpu for me as I only have 1 , but it'll show 2 for you.
also don't cut your self short aswell, make sure you add the passkey as your CPU points will be MASSIVE compaired to what you get without a passkey
31 Mar 2012
Thanks ozaudio. Did what you said.
Displayed PPD on FAH Control is now between 100k to 180k depending on what WUs they are up to. Certainly better than 30-50k prior to doing what you said.
9 Oct 2009
value : advanced
thanks for the tip just added it to both gpu's. :o
i got a passkey from when i was folding for linus tech tips and im using it on both rigs, is that the right way to do it or should i have one for each rig?:confused:
also does your signature update its self ? if so how do i get one
