- 1 Apr 2010
The table is in bad need of updating, surely the op still can't be on holiday as he has posted else where in the forums.
The table is in bad need of updating, surely the op still can't be on holiday as he has posted else where in the forums.![]()
^^^He got a three month ban from this section along with Spoffle, Greg and Rusty Galloway. Never forget fallen comrades.
[/SPOILER]
LMAO
That pic would look pretty cool if someone replaced the gravestones with graphics cards in photoshop.![]()
Why did they get banned?
Don't ask me about it here, already been warned once for discussing it.
He can, if you check the screeny it's only using x4 AA when it should be x 8
@jrodga2k5
You need to re run using correct settings
Whoops...my bad
Here we go with 8xAA
HD7990 (1119/6600)
Core i7 3770k @ 4.4Ghz
Ran a little comparison.
5.2% faster in FPS than a 7950 crossfire setup at matched clocks, maybe less if you take in to account pci-e 2.0 x8 x8 vs pci-e 3.0 x16.
Interesting comparison mate...
Obviously different CPU may make a slight difference too...your temps are so much better than mines tho![]()
The valley bench bottlenecks 3 or more GTX 780s or Titans, to see it run well you have to raise the resolution.
I score near enough the same @1080p as I do @1600p with my cards. The difference is at 1600p the cards have to work really hard and the temps reflect this.
