- 14 Mar 2011
But a combination of SD card, fast USB drive for artwork etc and a 2/3TB drive for content should be fine for 720/1080?
If you're playing media from a connected USB hard drive then of course network issues won't matter.
To anyone running raspbmc I'd also strongly recommend backing up the home directory to a different location (like your main PC). Doesn't have to be super regularly but at least once you get it setup how you like. Just means if you need to do a clean install you can quickly get things setup back how you had them (and won't need to re-scan and import all your media again either). I've broken my install twice now by letting the auto-update run, and a few other times it's just inexplicably broken itself - I'd turn it on one day and the network connection would refuse to come up, even after multiple restarts... If the home directory is backed up a quick re-install, copy it back over and you're as good as new
Just need a mains powered usb hub as the Pi doesn't have enough power to see my Freecom 500GB USB Hard drive
