Have you got ULPS off Stu?
No, ULPS was on. Will have a play with it tonight before I go back to 13.6.
My plan for having at least 3 hours testing the new drivers last night turned into 2.5 hours fixing eldest's PC and family laptop (he broke both trying to install the same thing, good effort!) and then only 30 minutes on my PC. Why does family, real life, work and sleep keep getting in the way of my cherished geek time?![]()
Matt - you're a star. Disabled ULPS and the issues with the FPS locking too low are gone. Very weird! I've played with ULPS before and it's never made a difference (even on 13.6) so it looks like the problem isn't 13.8, but 13.8+ULPS.
I have had to change my cooling setup, as previously I had the Windforce running the standard fan speeds and my Accelero set to 100% in CCC (obviously with ULPS it used to switch off completely when not needed). Why doesn't Afterburner allow you to set different profiles for different cards? Ah well, if I didn't have something to fix I'd only get bored and pull the PC
Well Installed and modded last night.
Working fine but...
Allbenchmark still will crash driver for me at frame 63xx where lazor cuts the building. Always same frame.
But games work good so![]()
Are there still no whql drivers since 13.4!? Why?
Good to hear Stu.
Are you 100% sure it was disabled correctly before?
You can use different profiles for different cards if you want. What you need to do is go to settings and untick sync settings for similar cards. Then create a profile for card one, save it to slot 1, then apply. Then go into settings and select card 2 as in the picture below. Then create a clock profile and save it to slot 2, then apply.
I prefer to have them synced though, even if it means i have to give one card a bit more voltage than is needed. But i can understand why you might want to do it, particularly if one card runs hotter than the other.
@Matt
Just to let you know I dont get no system hang when installing windows 8 13.8 beta 2 drivers
Guys (Sorry if its been asked before), AMD GPU owners, I've read a lot about the "bad" drivers from AMD but what experiences have you guys had compared to Nvidia?
