I don't mind what gametype gets played but AP/CM are really the only balanced types, the flaws in the other game types are fairly big.
Murray a lot of your past games feature lineups that are really heavy on level requirements (eg bounty needs 6 then he can ditch his lane or OD who needs W&E asap) or gold heavy (most carries), I don't think there's enough gold/xp available in lanes for some of the lineups you were in unfortunately
You seem to play a pretty good furion, assuming this is jungle you might want to check out the doom build I did last night as in beats the crap out of a lot of pubstars (OD/AM/QoP/Weaver/Puck) and you can midas in under 7 minutes if you get the right creep passives through your q. You don't even have to rely on your team mates and by 10 minutes you can clear out most camps each cycle.
Turbo edit:
Tryharding in a nutshell -
offensive tri-laning with doublestun&carry OR
defensive counter-attacker & stunner & farmer carry
One mid - can only pick from:
puck/QoP (gank team)
Magnus (lategame carry team)
One offlaner:
Darkseer farming behind their tower
Furion/LoneDruid with micro
weaver/bounty or something else invis
getting counter picked assumes we would have the co-ordination to pull off a counter strat (eg pushing vs team late game carry), not sure the newer guys would be up for this. I would like to see new guy CM though, but only if no one helps them pick
