*** THE LOWEST PRICE EVER ON A GTX 670 - PRE-ORDER ONLY!! ***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
This is a limited only deal, we do have a lot but at this price we expect them to sell out fast, stock is due this month:-
MSI GeForce GTX 670 Twin Frozr Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £161.99 inc VAT
Transform your gaming experience with the GeForce GTX670 Power Edition graphics card from MSI. Featuring the award-winning Twin Frozr thermal solution, innovative Military Class III component design, enhanced PWM configuration, and MSI's proprietary Afterburner overclocking suite, own the best graphics hardware with the GeForce GTX670 Power Edition from MSI.
The GTX670 Power Edition features the industry-leading Twin Frozr IV thermal design. With 8mm SuperPipes soldered to an all-copper, nickle-plated base, twin 80mm Propeller Blade fans, and a high density heat fin stack, the GTX670 Power Edition is up to 16C cooler than a competing design.
It also features Dust Removal Technology, which spins the fans in full reverse for 30 seconds at system start to minimize dust buildup and ensure optimal thermal performance. The GTX670 Power Edition also features a full-length heatsink that cover the front of the PCB, cooling and protecting critical components on the graphics card while preventing PCB flex.
The GTX670 Power Edition features a robust 6+1 phase PWM design that delivers 25% more current to the GPU versus the reference design for maximum performance and stability. This enhanced allows for better GPU Boost performance under load, and provides maximum power delivery and stability for gaming and overclocking.
MSI's Military Class III components meet a more stringent testing standard than industry-wide electronic components.
Utilizing the US DoD MIL-STD-810G testing protocol, Military Class III components are rated to run under the most strenuous conditions to meet the highest levels of performance.
These components include: Hi-C CAP -- Low profile tantalum core capacitors, more than 10 times the lifespan of traditional capacitors with 15 times less power leakage Solid State Choke (SSC) -- Pure iron core choke with high working current, designed for overclocking All-Solid CAP -- Nickle-plated cover for longer endurance, up to 10 years lifespan under full electrical loads
Features:-
- Innovative GPU Boost, NVIDIA PhysX, NVIDIA 3D Surround technology
- 3-way SLI, DirectX 11.1, PCI Express 3.0>/li>
- Twin Frozr IV Thermal Solution with Dust Removal Technology
- Enhanced PWM Design for increased GPU Boost headroom
- Full overclocking and monitoring via MSI Afterburner software suite
- Military Class III component design for maximum performance and power efficiency
Specifications:-
- Core Clock: 915MHz (GK104)
- Core Boost Clock: 980MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1344
- Shader Clock: 1830MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- With FREE Splintercell Blacklist PC Game
- Warranty: 3 Years
Only £161.99 inc VAT.
ORDER NOW
These are identical to the other Power Edition we sell, but with no overclock, so unfortunately these may not offer great overclocking ability as they are no doubt PE editions which failed the OC. Still for such a quiet card with good build quality this price is crazy and they will still BOOST well out the box. :)
Yes Splinter Cell is included, sell that for £20 and you just bagged yourself a 670 at sub £150 delivered. :eek:
amazing consider GTX 770s are still over £300 too
Yeah but 670 EOL so its simply a case of grab them whilst they are about, most board partners have now cleared all their stocks, so soon it will run dry.
Also 760 is closer to 670, as 770 is really a 680, but were selling 680's mega cheap too, so yeah right now 670/680 are the better value for money buys. :)
This is a mental deal, i am torn between adding a 670 to go sli. Or selling it and grabbing 2x7950's....
BF4 is the main reason, and i'll only game at 120hz 1080p.
