Hey chaps, I'm actually looking for a water repellent like RainX, but not for my car. For my shower screen!
I just spent some time removing hard water stains on my shower screen using lemon juice, then vinegar/bicarbonate of soda mixture, then vinegar/water mixture and finally rinsed off with clean water. It worked. It's a bit laborious though so I'd like to keep it that way for longer between major cleans other than my usual daily wipe down.
A youtube video shows someone spraying RainX onto his shower screen after he'd cleaned his to prevent or at least slow down the build up of soap scum and hard water stains. Seems like a good idea. It would make water bead off it like on windscreens. I found RainX at Halfords,
http://www.halfords.com/webapp/wcs/...01&langId=-1&productId=274597&catalogId=10151
Is there any other car water repellent product you'd recommend, maybe as good or better, perhaps cheaper or bigger bottle, or is RainX it?
I just spent some time removing hard water stains on my shower screen using lemon juice, then vinegar/bicarbonate of soda mixture, then vinegar/water mixture and finally rinsed off with clean water. It worked. It's a bit laborious though so I'd like to keep it that way for longer between major cleans other than my usual daily wipe down. A youtube video shows someone spraying RainX onto his shower screen after he'd cleaned his to prevent or at least slow down the build up of soap scum and hard water stains. Seems like a good idea. It would make water bead off it like on windscreens. I found RainX at Halfords,
Right, enough of this, after all, it's a car forum.
