Simple rules
Please use these settings below.
Please post your CPU and GPU clockspeeds.
Please post the drivers used (optional).
Settings
Scoreboards.
Scaling from one core to two is good, from two cores to four is poor.
7970 @1200/1823
2500K @4.5
Had to use fraps as the latest AB won't save screenshots :/
Pretty sure I got a few more fps without fraps... Ah well.
Good job Kaap. I always loved this game and the benchmark. I wanted to do a thread myself, but after the Tomb Raider debacle i decided to leave it for fear of getting lynched.
I will dig up my old 7970 results though they look rather dated now on older drivers. I'll also run some 7950 benches soon. I'm going to be putting accelero coolers on both my cards within a week so i should be able to squeeze more from my cards eventually.
Thanks, I am looking forward to your scores.![]()
Any chance you could post a thread with some pics and results if you do? I would love to swap my Windforce for an Accelero, but when I tried my current Accelero card in the top spot, it was almost touching my second card and the VRMs got so hot in Sleeping Dogs that the frame rate plummeted. Would be very interested how you find the spacing/cooling of the cards once they're 3 slotters.
Kaap why is there 10 fps difference between yours and Nockys scores when you're both running similar clocks?![]()
His cpu clock and slightly higher mem clock might have something to do with that methinks.
Pair of 7970's (1050/1500) and a [email protected], with the 13.8 beta 2 drivers:
Your score does seem a tad low Stu, i think. Will be interesting to see if others can run a comparison with 2x7970ghz cards at stock. Did you turn frame pacing off?
