Could someone please confirm if the game has a crossfire profile? I'm using the latest 13.8 Betas (2) and it doesn't enable crossfire for some reason. The driver release notes mention a performance boost for the game, but don't mention if it's for single or dual GPUs.
Thanks.
This looks good, back to basics yeah?
There is no CrossFire profile, create one using AFR, but the Uplay overlay needs to be disabled before you launch SCB.
If you don't know how to create a profile:
1. AMD CCC>Gaming>3D Application Settings.
2. +Add... Browse to Installation Directory and add Blacklist_DX11_game.exe
3. Select AFR friendly>Save.
Hiya guys, so this worth £29.99?
Which part if the redemption is failing mate?
Got this with gtx 670 I just bought. Controls are a bit iffy. Will try again with 360 controller.
No, but not bad if you grab one in the MM for £12. That's about what its worth tbh. It's good but nothing amazing.
Chris [BEANS];24827068 said:No chance anymore, they seem to all be gone. I've been looking![]()
