thanks somkedog
@ allnamestaken, how about trying some silica in the centre of your mesh wick? kind of like a hybrid wick of silica and mesh lol.
I honestly don't know if this is a good or bad idea as i have never tried it lol
The KFL is good but not 5 times as good as the ProTank, maybe three times as goodbut I never liked the ProTank. I don't like its airy draw. The KFL can be a right pain if not coiled right, as it can give very muted favour. I'm happy with the KFL but all depends on your budget. It's a bit like a Vamo isn't 5 times as good as ProVari. The Vamo will last a few months but the ProVari is like a tank. You are paying for quality and aesthetics plus it doesn't leak.
I just went and got some 100% cotton balls, it contains about 100 balls and I use less than quarter of a ball. So that's good for 400 rewicks.
Can I pinch your link to the tutorial you used (again)?
I'll see if cotton can be used in the Nautilus.
I built my KFL on my own experience, but its very similar to this
https://www.youtube.com/watch?v=zzmsM0b8ZOw
Not sure how well it would work in a Nautilus, as you need to feed it down the juice channels.
Top of the morning to you.
Im a smoker of over 20 years and am now desperate to ditch the fags. I have tried 2 or 3 different e-cigs and have been put off them fairly quickly. There is a horrible gas like after taste with the ones i have tried and i am researching better alternatives. I am looking for something that is fairly simple to maintain and something that will provide the nicotine with a taste that is palatable.
Could someone be so kind to point me in the direction of some options, cheers.
have a look at how funny this replica is one fast tech, for $20 i have got one, first is the genuine one by yellowkiss on vapist vapourisers its about £80
http://www.vapist.net/Ba_Gua_14500_Mod_by_Yellowkiss/p2068657_10408217.aspx
the fast tech $20 replica
http://www.fasttech.com/products/1/10005379/1435100-eight-diagrams-mech-mod-e-cigarette-battery
lol its a really good replica i have ordered one with another batch of stuff, if its crap i dont care it was so cheap![]()
Anyone had any experience of taking your kits/liquids abroad?
All will be in suitcase.
As mentioned in a previous post there is a lot of Jargon, am very very new to all this too (the same eCig pack as recommended by RedMogg) is in the post!
The following has helped me understand a lot, hope it helps!
http://www.vapeland.co.uk/vaping-101-school-12-w.asp
Take my eGo stuff on plenty of flights, even forgot I had one in my pocket, placed it on the tray with phone/wallet etc. Not a single eyebrow was batted
Question is can you vape on the flight, im off to Canada in a few weeks myself so wanted to know if its safe to vape??. Probably not as they will think its smoking when really it isnt...time to stock up on some nicotine gum i guess :/
