- 4 Aug 2007
- Wilds of suffolk
I use them quite a lot when its actually unnecessary for dipped beam, ie when I want to improve me being seen but when I do not need to enhance the visibility on what I can see. So times such as driving in a line of traffic when you just want it to be clear there is a car there but you do not need to add any visibility.
I think daytime running lights are really no diff to sidelights theya re just impossible to switch off so you have some lighting at all times. It becomes law at some point soon for all new cars to have daylight lighting.
When you need to improve the visibility on what you can see, then you need dipped beam, until this point you add sidelights to make yourself seen.
Also sidelights normally work with dipped beam, if you have a failed dip beam it stops you looking like a motorcyclist.
