Can't get the tablet to connect with the PC via USB at all to transfer files across... so annoyed!
Tried it and got Android 4.3 Issue 58277 Detected with Nexus Media Importer.
Had a look at this:
https://code.google.com/p/android/issues/detail?id=58277
Not going to do a hard reset.Anyone else want to try?
BSplayer does AC3, 99% sure MX does and I think the modified galaxy player does too. DD encoded is AC3 isn't it?
MX doesn't have DTS support natively (but you can put it in with a quick google) but I think BSplayer does to cover off the other SS codec of choice.
Well impressed with it so far, its a million miles from my ipad 2 which my son now uses.
Ordered a Poetic Slimline case for it and a Micro to USB Female connector so I can use a mouse on it when I need to RDP or remote my server, sames me taking my laptop when I go away.
Don't quote me on this but I'm pretty sure you need an OTG USB adapter rather than just a standard micro USB to female USB cable.
Something to with the Nexus acting as a host which it needs to do when connecting a mouse/keyboard/usb drive, if you connect it with a standard USB cable it'll be a slave rather than the host, and mice/usb drives etc won't work.
4G ordered![]()
