Hah cheers, I did try 125 but bailed.
Grunts.....im a silent lifter![]()
hows that bench press coming along? I still struggle with it no matter what I try.. faster/controlled reps etc don't seem to help! probably need to adjust my routine..attempted 140kg 5 times and just couldn't get low enough.. need to give 135 a go! nice work manhows that bench press coming along? I still struggle with it no matter what I try.. faster/controlled reps etc don't seem to help! probably need to adjust my routine..
what would a good bench press routine be? currently on 5x5 but it just doesn't work for me, what else could I try?
Ta
Hoping my Sqauts improve in the next few months
Bench press is non existant for me, I haven't touched flat bench for over a month now and I'm not intending to, my shoulder can't take the strain for some reason so it's DB incline only for me, even that is touch and go as to whether or not it aggravates it.
Why is 5x5 not working? How is it failing?![]()
its working fine for deads, bent over rows, squats etc I'm adding weight and getting stronger for sure but the routine simply does NOTHING bench press wise for me.. its as if my body refuses to get stronger at that part and trust me I'm farting it out as much as I can! jeez I nearly **** my self time I went for 70kg pb![]()
MoNkeE ------------ 100(+) / 165 / 190 ------------- [86] ----- 455
kthxbye
Yeah but I gain points from not being a belted phaggot![]()
. Dem dere creatine gainz!Yeah but I gain points from not being a belted phaggot![]()
kind of
