Man of Honour
- 21 Nov 2004
Nevermind, was running real nice until I started getting flashing texture boxes everywhere. Now can't get rid of them!
Nothing to do with the performance of my 670 in this game. It is ALL about some cpu bug. As soon as there are a lot of units or clashing units gpu usage can go as low as 36% !!!
Graphics look amazing and run amazing ....if you are just looking at a couple of units.
same with every TW game using this engine.
if they havent fixed it by now then they never will.
with shogun ive seen my gpu usage go <20%!
I have never had it as bad as Rome 2 though. I dont understand what CPU they run their preview videos on : /. They seem to have loads of units fighting without framerates in the teens.
Also this is the first Total War that actually seems to use all 4 cores quite a lot! Yet it runs worse than any of the others!
my game looked like that (extreme): http://s1.directupload.net/file/d/3369/xt2dh3uj_jpg.htm
Now i installed the directX version from the game (go to your Rome 2 folder -->redist-->directx-->DXSETUP.EXE
and now it looks better:
http://s14.directupload.net/file/d/3369/ngybfcnt_jpg.htm
the fps increase from 25 to 45 on my AMD 7970GHz Edition.
Maybe it is useful....
sry for bad english...
this worked for me i went from 50-60fps on my custom settings, on default extreme i gained 15 more fps - GTX660
Went from 8 to 18fps on extrame. 30 to 50 in medium. Somebody, get this guy a beer. Thanks OP.
It must not be set to update auto on install.
Lads, try this. I gave it a whirl and a few other are reporting minor success.
Dont understand why your still posting?
You havent played ANY of the games, you havent got this one, you dont know anything about it...
Dont get the point.
it was part of todays patch.
Don't you think you're being a little childish..... I've played the game and it really is not that bad. Sure it has faults but every game does, Rome total war did. No need to **** it off so much and then have a go at someone who actually enjoyed playing it....
In multiplayer can 5 or more of you play against AI? (Like old Rome Total War could!)
Or is it limited to a max of 4 per side?
