- 29 Jul 2013
all looks great, i think ill be picking up the fan controller soon!
Cracking build. Love all you component choices too. I used to have the V Gene and I was going to do a 350D build with it but I just don't have a reason for a 2nd machine.
looking goooooood
Not yet, sorting some other bits out with my pc first. From what i've seen, every fan controller that i've considered under further inspection has had issues. Sad isn't it! I'm sure that i'll get one eventually, just finding the perfect one that's all; especially as there is no urgency. My pc is very quick any way since I changed my h80i fans for 2 sp120'sThanks mate.
Did you get the same fan controller in the end? Im having a couple issues with it, its seems to turn off for no reason i can find and then turn on and when it turns on it will spin the fans up to full for 1-2sec and then settle down. It does it randomly and its so annoying!
IMPOSSIBLE I SAYive had a few fan controllers now and each one has had flaws.
All I want is something that looks like the Akasa, has at least 20w per channel, doesn't cost a fortune, has knobs/dials instead of touch screen, doesnt randomly ramp fans up for no obvious reason and doesnt cause other fans to change speed or make funny noises when adjusting a fan!
Anyone found anything like that?
IMPOSSIBLE I SAY
but they are soooo expensivelet me know how you get on with your fan controller, I feel an Aquaero coming on next month tbh
but they are soooo expensiveI'm going to be SUPER jealous if you get one though. Want to buy me one at the same time!?
yeah, Im not a fan of how they look, especially the touch screen one.haha nope!
If I get the one I would get the one without the screen, that way i can stick the front cover back on for a cleaner look
Really nice build there mate. Pity about the fan controller.
That Corsair case looks awesome and that board and colour scheme look fantastic
This looks brilliant, good job!
