Best case for £70-£80
Looks really good, but imagine it is a little noisy under load.
I have pretty much narrowed it down to the Shinobi or Ghost Silent.
The former is a bit cheaper but comes with that nice soft touch Matte finish, the latter looks to have better cable management, a cleaner internal look and nice way of opening it up.
For your budget, you can get Fractal Design Define R4 or R3. Its has a very subtle design, can be configured for silent or performance. But not sure the size is a bit larger than you need.
Nanoxia Deep Silence 1 or R4 sounds good although fractal have had build quality issues so might be a gamble on a fractal arriving all okay.
