iPad 4
25 Jul 2009
England
Hello.
Im looking at buying an ipad. I was going to get the ipad 2 16gb for £330. Ive been told theres an ipad 4. Ive done some searching and found out there is a 4 with retina display for £369.
Worth going for the four? I was going to go with one company as you can pay it back over 6 months or 12. I searched ipad four on there website but it just says "ipad retina display" not ipad 4.
Is it worth going for the ipad four over the 2 or 3?
Cheers
I would recommend the iPad 5, the main issue with the iPad 4 and one of the reasons for the success of the Mini is the size, its just a bit too big to be comfortable for prolonged usage. The iPad 5 has a narrow profile and very small side bezels similar to the Mini, it is also thinner so it should lead to you actual using the product more.
If you start waiting for new tech to come out you will never buy anything. why wait for the ipad 5 as the 6 will come out.
At the fast rate that new tech comes out unless it is a few days before it is better to get when you want and the upgrade in performance is never as good as they would like you to think but is it the only way to get you to buy products.
As Long as your happy but the iPad 4 is a lot better and well worth the extra 40 quid I have both the difference is quite big.
