I'm not biased. I own every major gaming system available bar the WiiU. And it sounds to me like you have a broken console, considering I game on my Xbox 360 pretty much every night and don't see "crappy stuttering graphics". You either need a new console or new eyes.
Edit: And what has your 360 got to do with his hatred of the original Xbox One policies?
I've had no less than three different xbox 360's - original one first launch, a black HDMI one, and now the slim model. I've also had a PS3, PS2, etc etc.
I notice that all the Xbox's stutter when playing certain games in intensive scenes and 'panning around' for example- compared to what my PS3 (original one). Yes, I've used titles that are cross platform and easily see the difference when playing between the two.
Don't believe me? check out batman arkham city on a PC with a similar spec to mine and compare it directly to the xbox version - its clear - no magic, no super-sensitive eyes - just plain and simple hardware struggling to keep up.
I have nothing against the Xbox one - I was merely pointing out seeing as most games I want to play are cross-platform (none of the exclusives really appeal to me tbh for either side) - the better option would surely be the console with the higher spec no? - This is taking into account it has double the shaders and DDR5 for memory (unlike half the shaders of the xbone, and DDR3 ram) - along with a higher clocked cpu (2Ghz v's 1.6Ghz). Titles don't matter as most of them will be cross-platform so that argument doesn't apply to me (and allot of other people)
In effect both consoles are based on the x86 architecture as we both know - so if we take a leaf out of the PC gaming scene (of which I also have a PC as per my sig) one shouldn't need to re-code the game to take advantage of the extra hardware the PS4 has (unlike the previous generation which was cell cpu v's whatever for example). In effect this would mean smoother gameplay and less of this stutter as the hardware struggles to keep up...... or is my logic flawed - hence my question. As a techie I always look at the technical specs first
EDIT: Gimmicks like kinect don't sway the playing field - they are laggy and hit'n'miss in my experience (yes I have a kinect too - it's been disconnected and sat in the corner and only got to see about 2 weeks of use!) oh and I've had both PS3 and Xbox's fail on me - they eventually do. In fact I might even hang fire and wait for the second generation models of both of these products before I purchase as the first ones always tend to have faults and die quicker!
