***Official 7950 Ice-Q Owners Club***
OcUk have sold a fair few of these bad boys, so the Lt and myself thought there should be an official thread just for the Ice-Q.
So give yourself a pat on the back as you picked one of the best if not the best 7950's out there, it is simply an awesome oc'er on the core(on the whole that Iv'e seen on my travels in here), and it has probably the best custom AIB cooler out there bar none especially if you are going CrossFire, in that case it's untouchable for cooling outwith slapping water blocks on top.
Although on the whole, it's a cracking card there are a few things you may need to know and this could save you time and effort as the last part drove me up the wall
First up, the not so bad, although the cores clock very well, the vram isn't as good as it's using Elpida, but core clocking far out ways vram clocking.
Next up, as generally it's the boost version most are using, it runs on a higher 1.25v default, there has been a few workarounds by making profiles in AB to lower stock voltage, the best way is flashing a custom bios-as it comes with a dual bios switch your sorted there.
Iv'e saved the most important for last, there is a flaw with the boost bios, it can cause gpu usage spikes=performance drop off in hard hitting titles(even oc'ed) therefore you may not be getting the full use of your gpu, but fear not, it can be fixed either with a bios flash or by changing the Power Limit in CCC by editing registry values if you feel uncomfortable about bios flashing.
Useful Info:
If using CrossFire, optimum performance requires you to 'disable ulps', Afterburner is the tool of choice but I found reg entries quicker to use but these ones only work on W7.
W7 Enable/Disable ulps reg entries:
Download Link
http://www.sendspace.com/file/5agn1h
The AC Extreme fits while keeping the vrm cooling plate intact.
If you are looking to watercool, EK's full face plate water block part number is -EK-FC7950[EN]
LtMatts Bios Flashing Guide, thanks to Matt.
***A few are having problems with the tool for creating a bootable usb, you can try this alternative app to format your keydrive into a USB boot disc if the one in matts guide is causing problems***
Alternative_Bootable_USB_Drive_Creator_Tool
***Run the app and point the tool to 'USB Drive Boot Files' then 'MS-DOS', create your boot disc then add ATIflash and the bios .rom of your choice.***
HIS 7950 Ice-Q custom bios Collection.
***Please check your other Bios is intact and working first***
***Dont forget to make a backup of your original BIOS(use GPU-Z)***
***Please only attempt if you know the risk of what you're doing, and if you can recover from a bad BIOS flash if something goes wrong...***
New bios for testing:
925/1250MHz Non Boost 1.175v -INCREASED TDP FROM 130W TO 173W-CrossFire users-ulps can now remain enabled with no performance loss!!!
This is a new bios that Matt and myself have been testing, further feedback welcome-especially if you are running CrossFire.
Matt's found you can overclock further before you need the power limit.
My own testing has achieved slightly lower voltage for my 24/7 clocks:
Before-1100/[email protected] +30% Power Limit
Using this bios-1100/[email protected] no Power Limit adjustment required.
Download Link
http://www.sendspace.com/file/risbea
1. 925MHz/1250MHz Non Boost 1.175v(0.950mv idle voltage version):
Download Link
http://www.sendspace.com/file/5mv49f
925MHz/1250MHz Non Boost 1.175v(0.850mv idle voltage version):
Download Link
http://www.sendspace.com/file/g8e0fl
925MHz/1250MHz Non Boost 1.175v(0.800mv idle voltage version):
Download Link
http://www.sendspace.com/file/560v3m
I have left the choice of three different idle voltage for those that want the lowest temps/system wattage possible, if you have problems, try the next one up as the low idle bios might not be suitable for certain cards.
Features of the Bios:
*Boost clocks removed
*Boost voltage removed
*Stock clocks so should work with all HIS 7950 Ice-Q Cards
*925/1250 clocks with 1.175v voltage. Should be good for large overclocks while keeping cool.
*0.075v reduction in voltage from stock boost bios.
*Custom Fan profile specific to the bios
30c=30% fan speed
60c=60% fan speed
90c=100% fan speed
*50% power tune for life
Bios created by Kaboom. His thread can be found here. All credits to him.
http://www.overclock.net/t/1395490/ati-hd-7950-7970-bios-mod-thread
2. 1000MHz/1400MHz Non Boost 1.18v:
Download Link
http://www.sendspace.com/file/qmiyyi
*0.07v reduction in voltage from stock boost bios.
*1000/1400 clocks with 1.18v voltage. Every Ice-Q should manage these clocks, any problems give your vram voltage a slight nudge.
Thanks to LtMatt/Kaboom
3. tommy's 925MHz/[email protected]/Aggressive Fan Profile:
Download Link
http://www.sendspace.com/file/15aa58
*Copied Kabooms settings adding an aggresive fan profile for max air cooling
*925/1250 clocks with 1.175v voltage. Should be good for testing large overclocks on max air cooling.
30c=30% fan speed
70c=95% fan speed
97c=100% fan speed
4. Stock Ice-Q Boost Bios:
Download Link
http://www.sendspace.com/file/y49731
Bios screens grabbed via VBE7 vbios editor
Useful Links:
His iTurbo 1.4.4(OC tool)
AMD - How to Change The Power Control/Limit from +20% to +50%(Software GPU Spike Fix)
****7950 (disabled) BOOST BIOS thread****(Includes Power Control/Limit from +20% to +50%) thanks to IC3
AMD: A fix for users with high "Boost" voltages(Lower Voltage via Software) thanks to Chrisoldinho
AMD - How To Overclock The Official Way Using Afterburner + Step By Step Overclocking Guide + Complete Driver Sweep thanks to LtMatt
**THE AMD DRIVERS THREAD** thanks to:
How To Make Sure Crossfire Is Working? thanks to LtMatt
EK Water Blocks EK-FC7950[EN] Full Cover GPU Water Block Review
Any other info will get thrown in here if it's worthy.
Happy gaming folks.
***Please remember when posting-this is the Official 7950 Ice-Q Owners Club-If You Haven't Got One, You Can't Get In!
.First up, the not so bad, although the cores clock very well, the vram isn't as good as it's using Elpida, but core clocking far out ways vram clocking.
Useful Info:
The first rule of crossfire club is disable ULPS.
Download Link
HIS 7950 Ice-Q Bios Flashing Guide - Remove the Boost Voltage of 1.25v, Stop Usage Spiking/Throttling - Give your card a Permanent +50% Power Line -
Bios Flashing Instructions
You might want to write this down...
You need to create a bootable usb stick.
1. Download and install the USB disk format tool here.
2. Download the Windows98 system files here.
3. Create a folder called Win98boot on your desktop, extract the files from step 2 into the folder.
4. Plug in your usb stick. Launch the USB disk format tool. Copy these settings, then click format. You need to select quick format, tick dos startup and select the Win98 folder, like ive done below.
5. Click start, then ok and it should do it.
6. Download atiflash. Extract it onto the usb stick.
7. Download my bios. Extract it and cut and paste it into the usb stick.
8. If you've done everything correctly your usb stick folder contents should look like this. (except the bios should say Matt.rom instead of HIS7950.rom) Do not worry if you have more or less files than what appears in the screenshot. As long as you have the bios file and atiflash thats all that matters. Windows 8 users might have extra files like in my screenshot.
If you look to have a file or two missing it could be because you don't have show hidden files ticked in control panel, folders.
9. Make sure all gpu's in your pc are switched onto bios 1.
10. Uninstall gpu drivers and any overclocking apps. Do not keep settings delete everything.
11. Restart your pc. Before you hear the beep keep tapping F8. Boot from the usb stick.
12. You should be at dos prompt. Type atiflash -i to get the adapter number for both your gpu's. Typically it will be 0 and 1, unless you have a gpu in a third pci-e slot. You need the adapter number to tell it which gpu to flash.
13. To flash gpu 1 type atiflash -p -f 0 Matt.rom and hit enter.
Wait for it to finish. It will prompt you to restart but before we do that we need to flash the second gpu as well.
Now do the second gpu (if you have one)
Type atiflash -p -f 1 Matt.rom
Once that has completed and you get a notification saying you can restart press Ctrl+Alt+Delete to restart your pc.
All going well you should get a display and boot back into windows. Now you can reinstall fresh new drivers etc. Boost voltage and boost clock is disabled, your card thinks its a non boost card from now on in and you have the option to select 50% power setting as standard with every driver install.
If something goes wrong and you get no display from the cards after flashing the bios. Turn the pc off and flick both cards bios switch to position 2 to use the stock backup bios. Turn the pc back on and all will be ok.
Good luck.
Good luck.
Download Link
Download Link
Download Link
Download Link
30c=30% fan speed
60c=60% fan speed
90c=100% fan speed
Kaboom said:New version VBE7.0.0.7 is up on my thread now. It now recalculates the checksum so it would work on any motherboard and have no issues, also has a better fan profile adjuster and custom modifiable power limits. Check here. Scroll down to the bottom of the tool section for a download
Download Link
Download Link
30c=30% fan speed
70c=95% fan speed
97c=100% fan speed
Download Link
Useful Links:
Happy gaming folks.
