Martian Orgy #5 Double DVD, only $9.99!
tehehehehe
Even if something like that did happen it takes like 30 minutes for the signal to travel from Mars to Earth so plenty of time to edit it out
tehehehehe
Even if something like that did happen it takes like 30 minutes for the signal to travel from Mars to Earth so plenty of time to edit it out![]()
7 years training, I expect they will all have specialist anlti trained to a lower degree than the specialist.
they cant actually do anything to the footage in that time though![]()
On a serious note, how would they broadcast from Mars to Earth? Might seem like a stupid question but would really like to know.
So I'm guessing that anything broadcast on TV here will definitely not be a live feed and will hit NASA first who will then edit appropriately?
How does the Mars base communicate with Earth?
All communication goes through satellites.
Both planets' orbits carry them to the same side of the Sun once every two years, at which point the distance between them totals roughly 55 million kilometers. At the opposite ends of their orbits – when Mars is one side of the Sun and Earth the other – this stretches to around 400 million. As communication signals travel at the speed of light, this means that it can take between 3 and 22 minutes for the information to reach the other end. A phone call would not be practical, but there would be no limitations to email, texting or 'WhatsApping' with the Mars residents. It'll just take at least 6 minutes for you to get your reply. Both voicemail and video messages are also easily workable options.
The astronauts can use the Internet, but can only surf 'real time' on a number of websites that are downloaded from Earth on the Mars habitat webserver. Every astronaut will have access to his favorite websites that way. Other websites will be very impractical because of the delay.
The settlement will be broadcasting images of daily life back to Earth 24/7, so that everyone can see what the astronauts are up to. Of course, they will be delayed by anything from 3 to 22 minutes, so they will be as close to live as we can get!
This expense means the Mars astronauts will have to be very self-sufficient. Should they send down a "Houston, we have a problem," Houston might not even know about it until 22 minutes later. Even so, we would not be much help: our fastest rocket will be scheduled to arrive six months after the fact.
Back to the FAQ overview
unless you can cope with a ping of 99999999
