Hi Chaps,
Quick question, would my system yeild much performance increase from:
i7 920@ 3.6Ghz /12GB Ram/ 7970 OC
To a haswell/ivybridge-e chipset/cpu? I use my system for gaming on 1 screen.
Thanks.
Id agree with lnoton here, i currently have the spec in sig and an i7 930 @4ghz, (also owned a 3570k and a 3770k). In games i play with one high end gpu there was no discernible difference with any of theese chips. It was only by moving to sli that i noticed a difference, the 930 was a slight bottleneck moreso the 3570k in multi threaded games. Id suggest clocking the 920 a bit more if you have a capable cooler. Which gpu are you using btw?
.still perfectly happy with my 920
Same, mine still working at 4.2GHz quite happily, never had any performance issues with it.
If I was to upgrade it would be the USB 3 and SATA 3, but there are adapters for that so even that's not necessary
Shame on AMD for not providing any competition in this regard!!!
