Most put it in the roof, exhausting out. It's the easiest setup.
That's a bad idea....
The air inside the case will normally always be hotter then the air outside the case, especially if you have GPU's that vent inside the case.
You want to pull the cool air from the outside the case and push that through the radiator and into the case.
Doing that on my old set-up resulted in 10c being knocked off my load temp.
/\ /\ /\ And there's the proof.
Whats the best way to set up a h100 into a case.
my case will be the corsair 540
