** GAINWARD GIVING OcUK CUSTOMERS MORE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I've negotiated with Gainward some special terms for OcUK:-
1. Very aggressive pricing, so great pricing on Gainward cards, including Phantom models.
2. Express 48hr RMA service with OcUK in the 2yr warranty period. If your card goes faulty, we shall endeavour to have it swapped out or refunded within 48hrs.
3. Removing heatsink/cooler will not void your warranty with OcUK or Gainward.
4. OcUK customers service of course, which is the best, plus these forums. ;)
Now onto some great cards and superb deals:-
Gainward GeForce GTX 780 Phantom 3072MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 902 MHz
- Core Boost Clock: 954 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£509.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 780 Phantom GLH 3072MB GDDR5 PCI-Express Graphics Card @ £529.99 inc VAT
Features:-
Specification:-
- Core Base Clock: 980 MHz
- Core Boost Clock: 1033 MHz
- Memory Clock: 6200 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£539.99] Inc. VAT
Only £529.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 770 2048MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2170MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£309.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 770 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom III comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 770 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 8mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8) which are also removable.
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Shader Clock: 2300MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £319.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 770 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
Specification:-
- Memory: 4096MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £379.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 760 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
This is serious equipment for the serious gamer.
Features:-
- Ultra Durable VGA Design
- WindForce 3x Cooler - Quieter, Cooler, better fans with Triangle Cool Technology
- GPU Boost 2.0
- Support up to 4 displays at single car and maximum 4k resolutions
- Direct Heat Pipe touch technology (DHT)
Specification:-
- Core Clock: 1072MHz (GK104)
- Core Boost Clock: 1137MHz
- Memory Clock: 6200MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 2144MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£209.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 660 Golden Sample 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
The Geforce ™GTX 660 extends the NVIDIA Kepler™ - powered family of graphics cards to new levels of affordability while retaining class-leading performance and power efficiency. It's the weapon of choice for gamers and a must-have upgrade for today's hottest games. The Asus GeForce™ GTX 660 graphics card represents the Kepler "sweet spots" for gamers - the ultimate combination of performance, power efficiency and affordability.
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1072MHz
- Memory Clock: 6108MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 960
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 130 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 650 Golden Sample 1024MB GDDR5 PCI-Express Graphics Card @ £79.99 inc VAT
NVIDIA launched a new era in gaming with the NVIDIA® Kepler™-powered GeForce GTX family. Now, there are two new ways to experience the fastest, most efficient and powerful generation of graphics cards for yourself. Take your gaming experience to the next level with the GeForce® GTX 660-the weapon of choice for gamers-or the powerful yet remarkably priced GeForce GTX 650. Choose your weapon. Game on!
Specification:-
- Core Clock: 1071MHz (GK104)
- Memory: 1024MB GDDR5
- Memory Clock: 5200MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 384
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI, 1x Mini-HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 100 watts at stock speed)
- Warranty: 2 Years
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Gainward GeForce GT640 2048MB GDDR3 PCI-Express Graphics Card @ £67.99 inc VAT
The Gainward GT 640 2GB supports all of the latest features of New GeForce 600 series, including Adaptive Vsync for smoother game play, PhysX, DirectX 11, and Blu-Ray 3D support. The GT 640 is also the first mainstream GeForce graphics card capable of driving up to 3 displays for surround gaming and general use, making multi-display more accessible and affordable than ever. The most common display types are supported right out of the box, including HDMI, DVI, and VGA.
- 384 Cuda Cores
- 900MHz Core Clock
- 1782MHz Shader Clock
- 2048MB GDDR3 Memory
- 1800MHz Memory Speed
- 128-Bit Memory Interface
- Connectivity: 1x Analogue, 1x HDMI & 1 HDMI
- Cool, Quiet, Fast and Affordable
- Better Videos, Photos, Web, and Games
- Greater Productivity
- SMX power efficiency
- Quad display support
- 9 x over integrated
- TDP 65W
- 2yr Warranty
Product Name : Gainward GeForce® GT 640 2048MB
Barcode : 426018336-2562
GPU : NVIDIA GeForce® GT 640
GPU Clockspeed : 900 MHz
Memory : 2048 MB DDR3 (128 bits)
Memory Clockspeed : 891 MHz
Pixels per clock (peak) : N/A
Bandwidth : 28.51GB/s
Ramdac : 400 MHz
Bus : PCI-Express 3.0
Cooling : 2-Slot Fan
Video-Features : HDMI
Connectivity : DVI-D + VGA
Product Size : 150mm x 112mm
Was [£79.99] Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
Great cards at very very good prices!!!! :D
let alone the pricing, the extra terms negotiated are pretty good. Although it's always preferable to never have to use RMA in the first place.
