no need for a 750w psi. Get a decent 600-620w psu indeed. I suggest seasonic or the antec HCP range.
CPU (Haswell) and Motherboard (Ivybridge) are not compatible.
Need a K CPU to overclock.
Also those PSU cables won't fit the PSU, better off with extensions
You should be ok with a 550w PSU.
YOUR BASKET
1 x Seasonic G series 550w '80 Plus Gold' Modular Power Supply £79.99
1 x BitFenix Alchemy Cable Bundle - Green £28.45
Total : £118.94 (includes shipping : £8.75).
@ OracIe, what are your cables like?
The ones my friend got didn't look good around the heatshrink (different lengths and not in the connectors fully), he was happy with them though.
That's over my budget I'm happy with the spec I have jus asking what cables I need extra apart from the bundle - plus I want to build in a parvum
