Caporegime
- 7 Apr 2008
- Lorville - Hurston
The pro 2 and its price point is a joke. You are better off buying a macbook air for similar price!
i'd agree about the resolution but touch support you dont neceariy need especially for desktop apps.With a worse resolution screen, no touch support, no active digitiser.
Plus Apple support for Windows was not amazing last time I owned a MBA it took an age to get full Windows 8 drivers.
The Pro is Ultrabook hardware, which costs Ultrabook prices.
What are your most used apps and games on RT?
Nobody would bet against you if you said Apple were going to announce a new iPad before Christmas.
Lots of reason, its not a tablet. Its 3.1lbs + 15.5mm thick.
Why the hell would you buy one, it just isnt a tablet and all though it folds back, realisticlaly stil cant be used as a tablet.
So yeah pretty much worse in every aspect that mattters.
Can you even reach the centre of a touch screen on a 13" screen. I think 11.6" is the biggest realistic size.
According to reviews it works perfectly well as a tablet. Surface 2 Pro just seems so expensive when compared.
It's actually very light considering its 13inch.
