- 21 Jan 2012
- Hereford, UK
Is sabertooth on par with crosshair? And is it better vrm over my board?
Putting my gpu under water should help my ambient temps or not?
I
Looks like from Avenged7fold post if I want 5+ I need crosshair board I may hold off on this and stic with 4.8 for now and invest in putting gpu under water.
I will post my gaming benchmark results tonight at 4.8 as you guys requested im keen to see results my self
The crosshair formula V is a bit disappointing in comparison IMHO. It runs quite stably at 4.8GHz, it does not feel quite as comfortable at 5GHz as my previous board.
Which was?
Are you using the older Crosshair Formula or the Formula Z?
The M5A99X Evo rev 1.0.
Surprising I know, I suspect that the bios for that board is better than the piledriver bios for the crosshair. Using the same or very similar settings, I was experiencing restarts on the crosshair. I have found stable settings now but the M5A99x seemed to go much higher in bus clock.
Another learning curve, I did experiment with water cooling the CPU only with a single thick 240 rad and found that the temperatures were very comparable within a degree or two to the phanteks high end air. I was unfortunate to experience a pump failure and have reverted to air.
Yes as you fsb goes up so does everything else so bring them back to near as possible to standard for now untill you find max overclock for cpu. Then try taking cpu/nb mhz up may have to raise voktage on cpu/nb slightly. Its hard to determine what is causing instability so do one at a time
With just the multiplier increase you are only pushing the CPU harder. When you alter the FSB it pushes the rest of the system (RAM, NB, SB) which is where you would lock off or apply dividers should your BIOS allow for it.
Purchasing better quality memory and motherboard allows to push the FSB higher.
