You have made me feel bad now
It will refresh at 144hz no matter what input you use unless you tell it otherwise.
Only Dual Link DVI (use the cable supplied) or display port will have the ability to provide the bandwidth. HDMI does not.
it didnt come with a cableYou have made me feel bad now
Im not sure about hdmi acctually, your best bet is dvi if the resolution is 1920x1080
