Caporegime
- 18 Sep 2009
- Dormanstown.
That is no indication of his system if you check his OP or his sig etc. Stop being a moron. Besides when I first posted you were still constructing your post as it initially said:
"If you want the best performance for rts do not go amd."
Nothing underneath so you must have edited.
Again, why would that be confusing? Because amd come up trumps in like Every rts game....
Xxxx
They are, but if you add up the component parts it works out cheaper I believe. Apparently they perform better than the H80/H100.
