First custom PC, need some questions answered.
Sorry. Didn't see your last post.
I'd say you've got a pretty sweet build there alas you appear to have forgotten to add any memory :)
Also as kefan stated, at 27" and PC viewing distances, 1080p can get a little ropey, you're better off with 2560 x 1440 at 27", but the cheapest one is £350 and is not a brand I'd personally choose. So I'd suggest saving yourself a bit of money as you've spent extra on the other bits and getting a good 1080p 24" like below.
YOUR BASKET
1 x Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black £139.99
1 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £55.99
Total : £207.98 (includes shipping : £10.00).
That new spec by TheReaperGuy is a very nice spec. I love that case it looks really slick.
There's only one Potential problem and thats that you'll use of all of your PCIe slots with just the two graphics cards and the sound card because the graphics are 3 slot cards. You should be able to fit the sound card in between them but you'll have no slots left.
Opinion is fairly divided on 27" at 1080p
A lot of people say its fine and many don't like it. A lot of it comes down to how far you are from the monitor (how deep is your desk?) and how sensitive you are to resolution. I don't particularly like 1080p on a 27" monitor, but then I saw a big difference between 480p/576i and 1080p, many people can't though. Personally I can't wait for 4K screens to come down in price a lot.
Regarding Windows 8 I'd say very little difference to most people.
http://windows.microsoft.com/en-GB/windows/compare
You get BitLocker, Remote Desktop Connection (you can do this for free very nicely with Teamviewer) and Domain Join in the Pro version.
Hello would you like to pick a colour please OP :D
I think the orange spec in the H630 would be saucy, I forgot all the nice coloured cables though.
@OP any reason for a GTX 780 when you can get sli/x-fire cheaper and more powerful, and that OC board I specced is a steal at a £10 off, I'd definitely be grabbing that.
@Ocean, thats true, but I dont think the OP will be going beyond 2 cards and a sound card, could always get the MSI's as they are a little better and 2 slot.
@OP again, with your budget you can have a beauty of a rig if you spend it right!
My Orange spec's are epic :p not to everyone tastes tho, and as for a stunning looking rig that always going to be the out come with me and Doomedspeed about :D
I agree I do like that Case a lot and orange just seems to work well inside a PC. I love the board you choose.
And yeah I doubt many people will use more than 2 GPU's and a sound card tbh, just wanted to make sure the OP was aware that he wouldn't be able to and another PCIe card at a later date like a couple of TV tuners or a wifi card (there's always USB of course) or raid card for example.
Oppppppsss........ I got carried away again :D
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £259.99
2 x Asus HD 7970 DirectCU II TOP 3072MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** £239.99 (£479.98)
1 x BenQ GW2760HM 27" Widescreen LED Professional Slim Bezel Monitor - Black £199.99
1 x Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £163.99
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £134.99
1 x Antec High Current Gamer 850W Modular '80 Plus Bronze' Power Supply (0-761345-06225-1) £119.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9) £89.99
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9R) £89.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £83.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £49.99
1 x Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) £49.99
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 60cm £25.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
3 x Corsair AF120 Quiet Edition Low Noise High Airflow - Single Pack (CO-9050001-WW) £13.99 (£41.97)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
1 x BitFenix Alchemy Molex to 4 x SATA power extension - Red £6.98
2 x BitFenix Alchemy 6pin PCI-E extension 45cm - Red £6.49 (£12.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Red £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - Red £3.95 (£15.80)
Total : £1,993.97 (includes shipping : FREE).
Ok lots of information I've been given now, I'll try answer everyone:
@Ethermaster, colour of the rig I want? I like black and blue, I feel they go nicely.
@oceaness, Maybe I should go to a store and see what 1080p looks like on a 27" monitor to me, also I will downgrade to standard windows now, saves some money thanks.
@ThaReaperGuy, What graphics card/cards would you recommend? also I'm not likely the orange on the board unfortunately.
edit: this is to the later posts not the current ones.
edit two:
YOUR BASKET
Nice build, I am going for blue n black I think mainly, also I'm not sure about water cooling since this is my first build and don't know if it is tricky to fit.
Oppps I did it again :(
YOUR BASKET
1 x MSI HD 7970 Twin FrozR OC BE 3072MB GDDR5 PCI-Express Graphics Card £254.99
1 x BenQ GW2760HS 27" Widescreen LED Flicker-FREE Slim Bezel Monitor - Black £203.99
1 x Silverstone Strider Gold Evolution 750w '80 Plus Gold' Modular Power Supply (ST75F-G) £129.95
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £74.99
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £74.99
1 x Creative Sound Blaster Recon3D PCI-E Soundcard - Retail (70SB135000002) £64.99
5 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Black & Blue £13.99 (£69.95)
1 x NZXT CB-LED10-WT 12x White LED Sleeve - 1m £9.98
2 x BitFenix SATA Cable 30cm - sleeved blue/black £8.99 (£17.98)
1 x BitFenix 24-Pin ATX Extension 30cm - sleeved black/blue/black £7.49
1 x BitFenix Molex to 4x SATA Adapter 20 cm - sleeved black/blue/black £5.99
2 x BitFenix 8-Pin PCIe Extension 45cm - sleeved black/blue/black £5.99 (£11.98)
2 x BitFenix 6-Pin PCIe Extension 45cm - sleeved black/blue/black £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99 (£9.98)
1 x BitFenix 8-Pin EPS12V Extension 45cm - sleeved black/blue/black £4.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Blue £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - Blue £3.95 (£15.80)
Total : £1,753.93 (includes shipping : £25.45).
The h100i is no more difficult to fit than an air cooler, and requires no maintenance. Here's a handy video:
