Woaa
Stuttering, Laggy, Jerky everything you can think of that might suit an Early Access release on kickstarter![]()
Try the nvidia beta drivers, fixed it for me.
Woaa
quick play just now, its just an update to BF3 offers nothing new that I can see, same textures, tanks and a few new weapons, meh! preorder cancelled
Absolutely golden on my systemi7 3770k and HD7990.
Enjoying the Map to be honest...just hate how the dust ruins the look after the building collapses![]()
Dat constant stuttering Seriously, it's almost unplayable for me, no matter the settings used
And considering the launch is supposed to be in a month I think, the performance is pathetic.
Tried the game again and its just a stuttering mess even with Vsync enabled from Inspector and all settings in low. Seems DICE perfected the Rubberbanding this time around. Atm this game to me is just a very shiny piece of turd, i know its Beta but still.
You got all that from a quick play of one map?
Impressive.
Plays pretty well, using the latest beta driver. Pretty hard to tell card usage, vram use etc as afterburner osd doesnt work.
If it's truly bf4 it should blow me away not look the basic same with a couple tweeks, this is bf3.5 at best
Will do.Mate check the AB monitoring when out of game, I want to know what your GPU usage is in SLI.
Ok I'm sorry beta or no beta this is aimed at consoletards big dumb polygon vehicles and naff textures, has PS4 XBONE all over it.
Next..
Will do.
tried 4 drivers so far
314.22 + 331.40 - microstutter and FPS drops from over 100fps to 40fps (ultra + 2xmsaa)
326.80 + 327.23 - unplayable even at lowest settings.
all in all its really unplayable for me since i need a smooth experience for shooters. might as well install the latest again and forget about the beta.
