Permabanned
- 9 Dec 2010
Sounds like they have a lot of optimization to do if it's running so poorly n SLI/XFire rigs.
If you do go xfire, yes an i7 will help a bit.Would hypertheading help ? I am not sure an 8 threaded, 4 core latest gen i7 at 4.5G would gain anything significant over a higher clocked 2500K ? And of course another 7950 for xfire.
Does a thread on a i7 2600k for example = the same performance as a core?
My cpu is 4 cores 4 threads a AMD cpu can have 8 cores.
Sorry for OT question![]()
So do we have enough evidence yet to see if LtMatt's predictions of 2GB VRAM not being enough to run more than 2xMSAA with playable framerates?
On ultra preset I had 2.7gb 1080p
Depends on the nature of the workload - I'm seeing good utilisation on all 8 threads (4 core + 4 hyper thread) though - tbh it doesn't seem to be stressing this CPU at all.
No, HT is way behind additional cores. It helps with software that expects more cores though for sure. If you look at the BF4 graphs for AMD CPU usage it maxes out the six cores of the 6300, and puts the 8350 under quite heavy load.
Thanks.
So do you think a AMD cpu will start showing it's worth with next gen so called games?
As a generalisation yes but it depends a lot on the nature of the workload and in BF4 it seems to utilise HT threads well.
Tried a brief blast earlier with ht off, was very stuttery and cpu use was quite high. Gpu use didnt go over 80%. Pretty much the same as when i had a 3570k.
And did it NEED all 2.7GB or did it just use it because it could?
Like how people that drive a Porsche 911 (or similarly fancy car) will use 2 car parking spaces even though they only need one, because they found 2 next to each other and thought "**** it I'm special cuz I've got a nice car so I'll use 2 spaces and those common people with cheap cars will have to find somewhere else to park that not near me".
lol I get better results holding the clocks back to 1.2GHz (and not a huge drop in performance from normal clocks with HT on) with HT on than letting it run full whack with HT off at almost 4x the clock speed. (its a stuttery mess with HT off). Only casual observation but looks like its been optimised for 8 low performance threads for the sake of it........
Absolutely appalling stutter on an i5 clocked at 4.5GHz, but fine on an i7 at stock. It seems that when a game expects more than 4 cores and is CPU heavy, it causes some thread bottlenecks on the CPU that result in stutter. The average FPS is probably not all that different.
